Oil Priming Question
Old Jul 24, 2008 | 12:38 AM
MonsterB's Avatar
MonsterB
Default Oil Priming Question
I am ready to fire the stang. i am spinning the oil pump. the valve convers are off, shouldnt i see oil on top of the heads. Does the engine actually need to be running to get the rocker arms wet?
I dont wanna turn it over if there is no oil flow!
Old Jul 24, 2008 | 02:18 AM
jwog666's Avatar
jwog666
Default RE: Oil Priming Question
i have never had luck getting oil at the rocker arms while priming. i usually install a mechanical oil pressure guage and then prime the engine making sure that it has good oil pressure. i think to get oil at the rockers that the engine has to be rotating. doing this i have never had a problem
Old Jul 24, 2008 | 03:30 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
it takes a while it will get up there have you builf up any resistance?
you got the oil gallery plug in thats in the rear of the block under the intake right
Old Jul 24, 2008 | 09:34 AM
davesanborn's Avatar
davesanborn
The oil pump doesn't "spin". It's bolted onto the block. You're spinning the oil pump driveshaft.
You do realize that the oil pump driveshaft spins counter-clockwise, right?
Dave
Old Jul 24, 2008 | 10:05 AM
MonsterB's Avatar
MonsterB
Dave, i did not know that the shaft spins counter clockwise. This being said, i assume the the drill needs to be in reverse. i know the question seems redundant but i just want to be sure.
If i do this, will i then get oil to the top of the heads. IE, get the rckers wet?
Old Jul 24, 2008 | 10:33 AM
MonsterB's Avatar
MonsterB
dave
thank you for the tip. i spun it counter clockwise and oil came up through the pushrods and soaked the rockers. that is what i was looking for.
Old Jul 24, 2008 | 02:19 PM
davesanborn
Now that you know the oil pump drive shaft spins CCW, guess what else does? The distributor rotor. If you ever have to change your spark plug wires, remember to route them CCW following thefiring order.
Glad to be of help.
Dave
1TUFF302
Nov 5, 2015 04:02 PM
04stangman
Sep 17, 2015 01:45 PM
tramphardrocker
Sep 13, 2015 08:56 PM
kevsgt
Sep 9, 2015 06:20 AM
