Tail light - Help Please
Old Jul 29, 2008 | 10:46 AM
Jstang's Avatar
Jstang
Default Tail light - Help Please
Can anyone help me out with my 66 mustang?
Problem: When I hit the brakes the tail lights dont get brighter. Turn signals work and the tail lights light up with the lights are on but when I hit the brake they stay dim!? I bought new bulbs and still does the same thing? Can anyone give me tips on what maybe wrong? I hate wiring problems.
Thanks in advance
Old Jul 29, 2008 | 10:50 AM
1slow67's Avatar
1slow67
ROTM Moderator
Default RE: Tail light - Help Please
Possible brake switch is bad.
Old Jul 29, 2008 | 10:53 AM
Jstang's Avatar
Jstang
ORIGINAL: BA Mustang
Call me a newb.....but where is that located at? Also, where is a good place to pick one up.
THanks
Old Jul 29, 2008 | 11:02 AM
1slow67's Avatar
1slow67
ROTM Moderator
It is hooked up near or on the brake pedal shaft. They should have them at a local auto parts store.
My switch looks like this.
Old Jul 29, 2008 | 11:35 AM
Starfury's Avatar
Starfury
Napa Part ECH SL200
Old Jul 29, 2008 | 01:01 PM
kalli's Avatar
kalli
you can see the two pins where the cables connect to?
disconnect both cables and connect the two cables with each other temporarily
best thing is to use a small piece of cable and plug it into each of the cables that go there.
When your brakelights work with those 2 connected, then you know for fact that the problem is the switch. Either not adjusted properly if they can be adjusted or just faulty
Kalli
Old Jul 29, 2008 | 02:35 PM
Jstang's Avatar
Jstang
Thank you all very much. Im going to get on it right away.
This site is simply the best for information.
Old Jul 29, 2008 | 03:28 PM
jlg2002's Avatar
jlg2002
And if you put the cable accross the brake switch plug terminal sockets,and the lights don't get brighter, replace the turn signal switch.
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
folivier
Tennessee Regional Chapter
Oct 2, 2015 05:32 AM
ChampInSD
Oct 2, 2015 04:55 AM
