firewall hard shell connector?
Old Jul 30, 2008 | 11:38 PM
kaiser18's Avatar
kaiser18
Default firewall hard shell connector?
I'm going through the process of replacing almost all my wiring from the firewall out. The harness I purchased noted that I would need to purchase a new firewall hard shell connector for the 14 colored wires I need to install... but it also goes on to say that this part is no longer manufactured and I need to reuse my old one or purchase a used one... talk about contradicting its self. So now I'm a little confused as to what my next step is.
Also to anyone that has done this before, Is there any chance of royally screwing this up when I unplug the old hardshell that houses the currently used 14 wires?
Thanks
Old Jul 30, 2008 | 11:49 PM
4reboy's Avatar
4reboy
Default RE: firewall hard shell connector?
sorry I can't really help you, but have you tried painless wiring systems? they might have something.
and I just wanted to say BEAUTIFUL car, it looks great.
Old Jul 31, 2008 | 11:26 AM
kaiser18's Avatar
kaiser18
Thanks, but no painless doesnt seem to have the connector.
Old Jul 31, 2008 | 02:26 PM
davesanborn's Avatar
davesanborn
Your local Radio Shack has the connectors that you seek. They'll also have the correct male/female pins to build the connectors and the special tool to pop the pins in and out of the connectors (It's approx. $5 and worth every penny).
The connectors are cheap and the whole process is fairly straightforward.
After you've finished building your new connectors, it's a bear to get them connected together. It took me awhile to figure out why. The problem is you're trying to force 6,8,10,12 new male connectors into 12 new "virgin" female connectors all at the same time. The "virgins" of course are resistant to initial penetration.If it was just one virgin pin connector, you could easily force/insert the male pin, but when you're talking about 12 at once, it's almost impossible. Each female pin needs to be "broken-in" a little bit before the two halves of the connector will easily snap together. Utilize some loose extra male pins to loosen up each female pin by repeatedly inserting the male pin into the feamle pin. Some dielectric grease also helps with the pin insertion.
Good Luck!
Dave
jwog666
Dec 27, 2021 08:09 PM
UrS4
Oct 3, 2015 06:23 AM
guitarman376
Sep 30, 2015 05:54 PM
1996cobraconvertible
SVT Forums
Sep 30, 2015 02:01 PM
RCS02v6
Sep 29, 2015 01:46 PM
