67 Disc / Master cyclinder Q ?
I took the complete single piston disc brakes from a 67 to put on my 67. First problem is I guess there are differences in the early and late systems and I don't know how to tell?
Second.. I want to dump the brake booster and just just a manual master cyclinder. IS there a manual disc master ? also is there maybe an Alum master of a later car that will work?
There are manual disc MC. You can get then you buy the manual disc conversion. Here is a link to what you want.
http://www.mustangsunlimited.com/ite...p?T1=101518+01
Autozone or any parts store has a manual Disc/Drum manual master cylinder for a 67. Not sure why you believe there is a difference between early and late.
Remember the front bowl goes to the back and the back bowl goes to the front brakes
ORIGINAL: JamesW
To my knowledge, all 67 models came with 4-piston KH-style calipers. 68+ models came with single piston sliding calipers. Master cylinders should be the same, though.
I would look on ebay for what you need, good place to buy that stuff as it can save you $$$.
