Sending Unit Question
Old Aug 5, 2008 | 03:45 PM
jmstang68's Avatar
jmstang68
Default Sending Unit Question
I have finally put the new gas tank in the car. The problem is that my 68 has an optional convienence package for low fuel, seat belt, door ajar, and park brake. My wiring will not hook up to the new sending unit. My wire plug is a 2 prong push on type. The sending unit only has a threaded bolt coming out. I guess you cannot find the sending units with low fuel for a 68. So, has anyone else experienced this and what did you do? Any one have any suggestions? Any help would be appreciated. I guess sometimes it doesn't pay to have rare options......
Old Aug 5, 2008 | 06:14 PM
rst08tierney's Avatar
rst08tierney
Default RE: Sending Unit Question
What I would do is just buy a new sender and float and use you old hardware. Is something wrong with the actual unit? Usually its the float that goes bad.
Old Aug 5, 2008 | 06:34 PM
jmstang68's Avatar
jmstang68
The only problem is that I no longer have the old tank. The body shop that did my quarters and floor pans tossed it. Not sure what to do now. Do most sending units just have a single wire running from it? I cannot believe there is not a single adaptor or something that I could use.
Old Aug 5, 2008 | 07:15 PM
davesanborn's Avatar
davesanborn
Yes.
I know this doesn't do you any good, but for the benefit of others to come, this is a perfect example of why you NEVER throw anything out until th ecar is 100% finished.
Dave
Old Aug 5, 2008 | 07:48 PM
Nabster's Avatar
Nabster
Would this help you?
http://mustangsunlimited.com/itemdy00.asp?T1=F008+01
Old Aug 5, 2008 | 09:18 PM
jmstang68's Avatar
jmstang68
Dave, I couldn't agree more after what I am going through. Luckily, I have kept everything else. Who would have know a gas tank was this important. Nabster, thanks. I will check this out and see if I can get it to work.
Old Aug 5, 2008 | 09:26 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
this is a perfect example of why you NEVER throw anything out until the car is 100% finished.
davesanborn
Maybe you should take your lectures elsewhere, to a convention of people that like lectures.
Bill Slowsky
Old Aug 5, 2008 | 11:37 PM
rst08tierney
ORIGINAL: jmstang68
Man, like dave said, dont ever throw anything away.
All I can say is keep an eye out on ebay because everything will be single wire since its the most common option.
Old Aug 6, 2008 | 11:28 AM
sixpony66's Avatar
sixpony66
I would add a pigtail for the one wire unit with a clamp on type splice that can be removed later, that way at least you'll have a gauge til you find the correct sending unit.
Old Aug 6, 2008 | 06:46 PM
jmstang68's Avatar
jmstang68
Thanks guys. Tough lesson learned by a first time restorer. If any of you ever come across one of these sending units, please let me know....
vbonina
Sep 22, 2015 08:31 AM
yourmom6990
Sep 14, 2015 10:52 PM
cbird1177711
Sep 2, 2015 08:51 PM
cbird1177711
Sep 2, 2015 04:12 PM
