Master Cylinder Help!!!
Old Aug 5, 2008 | 05:56 PM
Meadracing's Avatar
Meadracing
Default Master Cylinder Help!!!
I am in the prosses of swaping out my single bowl to dual bowl master cylinder. How do I get the push rods out the master cylinders. Thanks for your help.
Old Aug 5, 2008 | 06:08 PM
jamieNerikas66stang's Avatar
jamieNerikas66stang
Default RE: Master Cylinder Help!!!
hahahaha, i went through the same thing, i tied the push rod to my cars axle and the master to another cars axle and had to put the car in drive to separate them,..i played with it for 2 days before this and could not get them apart,...
Old Aug 5, 2008 | 06:29 PM
restomod66's Avatar
restomod66
I will be doing this soon so keep me posted!!!!
Old Aug 5, 2008 | 06:53 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
Lock the end of the pushrod in a vise or something, push the MC towards the rod (to get a running start) and then give the MC a serious yank.The plastic retainer should snap and allow the rod to come out.
Everybody buys the kits.
Phooey.
If you use the MC from a 1974 Maverick you won't have this problem. The Maverick MC comes with a new rod that is the same as the one in a Mustang. The MC bolts right in, new rod and all.
Old Aug 5, 2008 | 07:19 PM
Meadracing's Avatar
Meadracing
So your saying that it just takes alot of force and there's no real trick to getting it out. I want to get this done before my Cragar SS wheels show up thursday.
Old Aug 5, 2008 | 08:43 PM
Oxnard Montalvo
Yep. It's a plastic/metal retainer which will probably break when you pull it out, but it's really not necessary. The rod's going to stay put anyway.
Old Aug 5, 2008 | 10:04 PM
hazmatpony's Avatar
hazmatpony
I had the same problem with mine, racked my brain for hours! Then I did some research, and ended up putting the m/c in a vise and attatched a slide hammer to the pushrod, and after about ten minutes, voila! Just remember, when you reinstall the pushrod, it will not be locked into the new m/c, which is fine, as long as you don't put your foot under the brake pedal and pull up (learned that thankfully with car still on jackstands).
GimpyHSHS
19
Dec 19, 2023 01:12 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
b8checker
Oct 8, 2015 12:55 PM
Dathan
Oct 5, 2015 05:52 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
