bearings
Old Aug 8, 2008 | 11:18 PM
javier146's Avatar
javier146
Default bearings
Just bought a detroit truetrac with 4.11. gears and installation kit. The bearings in the installation kit don't fit the posi, so now what do I do? Do they make different sized bearings for 8"?
Old Aug 9, 2008 | 11:08 PM
jasond393's Avatar
jasond393
Default RE: bearings
I would call eaton. Give them thepart numbers off of your original bearings and tell them abouth the problem that you are having and I am sure that they can give you the part number for the bearings that you need.
Old Aug 9, 2008 | 11:11 PM
jasond393's Avatar
jasond393
Eatons phone number is 1-800-328-3850, then dial extension 6762. I forgot what his name was but he helped me out on my detroit locker and he knows what he is talking about. Just be sure to have the original bearing part numbers when you call, and it wouldnt hurt to measure them also (the outer race) in case he dosent have anything to cross reference the part numbers you have.
Old Aug 9, 2008 | 11:32 PM
javier146's Avatar
javier146
Luckily, I found a part number from a manufacturer of bearings that was different from the original bearings. Took it to Napa, and sure enough it fit the posi.
Old Aug 10, 2008 | 11:56 AM
jasond393's Avatar
jasond393
Post the part number so if anyone else has the same problem they can find this thread and know what to use.
Old Aug 10, 2008 | 04:45 PM
javier146's Avatar
javier146
LM102949/LM102910 for race and bearings
6bangr
Feb 15, 2016 07:40 AM
KingRando
Oct 2, 2015 08:06 AM
allenmaty
Sep 24, 2015 09:17 AM
Offendant
Sep 23, 2015 07:21 PM
ccdguy
Sep 19, 2015 05:20 PM
