parking brake
Old Aug 9, 2008 | 10:29 PM
cxr's Avatar
cxr
Default parking brake
who has the diagram or directions on how to tighten the parking brake?
i guess its supposed to lock at like 2-3 indents.
Mine pulls all the way out. we installed the new 8" rear end and replaced the rear drum setup. im not sure what we did about the parking brake cable, i know we installed it but guess we did not tighten it
Thanks
Old Aug 9, 2008 | 10:32 PM
4reboy's Avatar
4reboy
Default RE: parking brake
I'm going to keep an eye on this, I've never been able to get mine to work (not like i need one with an automatic [&:])
Old Aug 9, 2008 | 11:18 PM
cxr's Avatar
cxr
came across this after a lengthy web search:
https://mustangforums.com/m_5021457/tm.htm
Old Aug 9, 2008 | 11:25 PM
cxr's Avatar
cxr
ohhh found this on autozone web site:
1966-73 Models
The procedure for adjusting the parking brake on all pedal-actuated systems is as follows:
Fully release parking brake. [*]
Depress the parking brake pedal one notch from its normal released position. On vacuum release brakes, the first notch is approximately 2 inch of travel. [*]
Taking proper safety precautions, raise the car and place the transmission in neutral. [*]
Loosen the equalizer locknut and turn the adjusting nut forward against the equalizer until moderate drag is felt when turning the rear wheels. Tighten the locknut. [*]
Release the parking brake, making sure that the brake shoes return to the fully released position. [*]
Lower the car and apply the parking brake. The third notch will hold the car if the brake is adjusted properly. [/ol]
Old Aug 9, 2008 | 11:32 PM
restomod66's Avatar
restomod66
Guys,
Try this link I think it will help you out!!
http://www.mustangmonthly.com/howto/...air/index.html
bradleyb
Nov 27, 2015 07:50 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
