Base/Clear vs. Enamel Paint
Old Aug 11, 2008 | 11:47 AM
1965fastback's Avatar
1965fastback
Default Base/Clear vs. Enamel Paint
Which is easier to paint at home in a garage, base/clear or enamel? I am wanting to paint my car on my own, it will be my first car to paint, so which should I use? Thanks in advance.
Old Aug 11, 2008 | 12:11 PM
TripleHmotosports's Avatar
TripleHmotosports
Default RE: Base/Clear vs. Enamel Paint
BC/CC is easier to spray and last longer.
Old Aug 12, 2008 | 02:33 PM
zggill04's Avatar
zggill04
Not only that but better looking... as long as you do it right. The clear is your protectant and shine, I suggest BCCC. When I was doing body that's all we did, even on the classics. Know a guy that sprayed the enamel and wasn't happy with it so he went and sprayed the BCCC.
Old Aug 12, 2008 | 05:01 PM
65rangoon's Avatar
65rangoon
ive sprayed both and to me they are about equal. Last i knew they also had an enamel clear.
Really it comes down to how original you want the car on if you go with the original enamel paint or the base clear.
From there they have different clear coats as well. PPG has a DBU & a DBC one you can wet sand and polish out the other, is pretty hard and isnt that forgiving and cant really be wet sanded.
The prep work makes the paint job as wel. if you dont have a smooth surface it shows right through the paint and makes the paint job look crappy.
again neither are that hard IMO ... if i were to do it though id do the B/C but go with a good PPG/Dupont and not the cheap OMNI that PPG has or any single stages.
tri stage paints can look really good but are a PITA if you have to reshoot any
Oct 1, 2015 09:29 AM
mungodrums
Sep 28, 2015 10:54 PM
GLOCKer
Sep 28, 2015 07:36 AM
JT76
Sep 20, 2015 11:32 AM
mustangchef
Sep 4, 2015 08:08 PM
