Disc Brakes
So I'm fairly sure my rotors aren't warped although I do get a bad vibration in the steering wheel when I brake.
I've attached a few pictures of my master cylinder. Can someone tell me which valve is the proportioning valve.
Thanks
Thanks
thats your dual master cylinder. If you follow the line that feeds the rear brakes there should be an adjustable valve somewhere along the line. Id post a pic of mine but i have not figured how to do that on new forum
You said the brakes suck, exactly how?
Besides the proportioning valve, your calipers could also be frozen. The pistons that push against the pads get stuck in their bores. It's a fairly common problem, especially with cars that are not driven regularly. Jack it up, spin the wheel and mash the brakes. The wheel should really lock up and release when you take your foot off the pedal.
Most auto parts places are supposed to measure disks/drums prior to turning. They'll let you know if they're beyond the limits. Double check the proportioning valve also, the front should dip slightly when the pressure is greater up front. Just a suggestion!
