My headlights/dash lights blink...
Old Aug 15, 2008 | 10:04 AM
pwrl3ss's Avatar
pwrl3ss
Default My headlights/dash lights blink...
Hi all,
I took my car out to the store at night and notice the headlights and dash lights are now "pulsing". They pulse at a steady rate; sitting or moving, they stay at the same rate.
It wasn't doing that the first few times I drove it at night, but now it's all the time.
I'm not sure if the dash wiring has ever been replaced after 40 years, but could the alternator or solenoid be causing "interference" to make it pulse? Any thoughts?
Thanks
Old Aug 15, 2008 | 10:09 AM
ThanksDad's Avatar
ThanksDad
I went to my local auto parts store and got a Electronic Voltage Regulator (the one under the hood not behind the dash). For about $15 it solved my pulsing problem.
Since it's electronic there are no moving parts like the old one. I like the look of the shiny cover but I am told with a little work you can put a OEM looking cover on the electronic unit.
Old Aug 15, 2008 | 10:37 AM
pwrl3ss's Avatar
pwrl3ss
Thanks ThanksDad .
Old Aug 15, 2008 | 10:45 AM
SJs 66coupe's Avatar
SJs 66coupe
I had a problem with mine a while back where it started with the dash lights going out sort of going on and off then later the headlights started doing the same thing.
Mine were not "pulsing" at a steady rate or anything however.
The fix for mine was to replace the light switch.
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Explosive
Oct 2, 2015 07:45 AM
ChampInSD
Oct 2, 2015 04:55 AM
