289 Engine Problem
Old Aug 22, 2008 | 09:56 AM
cmalueg4's Avatar
cmalueg4
Default 289 Engine Problem
I have a 67 Mustang, with a 68 289 motor. I think it is from 68, not really sure. The problem is when the engine warms up, it will get really doggy (loose power), then if I let it cool, it will run fine until it gets to a certain temp., then it will get doggy again. Already replaced the air filter, carb, and fuel pump. What is wrong. Thanks.
Old Aug 22, 2008 | 10:26 AM
kalli's Avatar
kalli
maybe your engine is running too rich, with what it can cope if it's cold but not when warm ? Id check on:
a) in case you have breaker point in distributor, check dwell
b) then check ignition timing
c) then check if your choke oiperates properly (the top butterfly in carb needs to be fully open when engine is warm)
d) then adjust the idle mixture when warm
e) then spray some WD 40 around the carb when engine is running (not into the carb or airfilter)
if engine idle changes you are pullig false air at where you are spraying. Fix that leak
Old Aug 22, 2008 | 10:29 AM
kalli's Avatar
kalli
oh and check the color of the spark plugs indicating rich/lean/detonation ...
Old Aug 22, 2008 | 10:38 AM
cmalueg4's Avatar
cmalueg4
Thanks for the info, hopefully one of those things work.
djbigskrilla
Sep 20, 2022 01:04 AM
kdryan
Aug 21, 2015 04:01 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
ding56
Aug 14, 2015 02:40 AM
HIS S-197
Aug 10, 2015 05:47 PM
