Which Master Cylinder?
Old Aug 24, 2008 | 01:38 PM
MonsterBilly's Avatar
MonsterBilly
Default Which Master Cylinder?
I have a 66 with the stock drum breaks all around. Factory v8. i need to install a new master cylinder for a short time to get the vehicle on the road. which dual cylindr master cylinder will work.
I dont want to make it to complicated because i am swiching to disc in the nex couple of months
Old Aug 24, 2008 | 03:26 PM
Starfury's Avatar
Starfury
I believe a stock '67 m/c will work, although you may need to retain your original pushrod. The Napa # is UP 36251 (new), or TS 101378 (reman)
Old Aug 24, 2008 | 07:26 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
The master cylinder for a 1974 Maverick will bolt right in and comes with a new pushrod identical to the one in a 1966 Mustang.
The problem is that drum brakes use a different MC than disc/drum brakes, so if you are going to change over you will have to buy another MC.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
b8checker
Oct 8, 2015 12:55 PM
Dathan
Oct 5, 2015 05:52 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
