Compressor Rebuild
Old May 16, 2005 | 11:32 AM
jrrhd73must's Avatar
jrrhd73must
Default Compressor Rebuild
Has anyone rebuilt a compressor? I have a 73 that used to blow cold air. I know there is a leak and I have recharged it a few times. I would like to rebuild the old compressor and convert it to 134. I have converted many other compressors. I would like to keep the look of the old compressor even though the air will not be as cold if I put on a new compressor.
Thanks,
John
Old May 16, 2005 | 12:52 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Compressor Rebuild
Are you sure the leak is from the compressor and not at a joint in the pipes? Anyway, here are a couple of tech articles you might find useful. I'm wondering how you are going to get the old R-15 out. You can't just let it fly. There is a tough law against this, thanks to the EPA. That will have to be done at an airconditioning place where they take it out and store it in tanks.
http://www.hotrod.com/howto/7954/
http://www.hotrod.com/howto/7975/
Old May 16, 2005 | 01:54 PM
jrrhd73must
I understand the laws. I also doubt there is any left in it. If you are servicing R12 you have to use a recovery system.
Thanks for the links. I will check them out.
Old May 16, 2005 | 02:08 PM
Soaring's Avatar
Soaring
I ♥ Acer
OK, good luck with it buddy. And let us know how it turns out.
Dathan
Oct 5, 2015 05:52 AM
fastbackford351
Oct 1, 2015 12:24 PM
Drastang
Sep 30, 2015 03:48 AM
marc954
Sep 29, 2015 03:05 PM
marc954
Sep 25, 2015 06:48 AM
