1966 Floor Pans
Old May 17, 2005 | 02:30 PM
RobB66's Avatar
RobB66
Default 1966 Floor Pans
Hey guys, I just joined the forums. My '66 is ready for new floors. Anyone have any suggestions for which type...the full pan or the seperate pieces? Do you guys know if it's better to cut the floors out and butt-weld the new ones in? Or is it better to try to mimic the factory spot welds? Or should I use a lap weld? Any input you guys have would be awesome. Thanks.
Old May 17, 2005 | 04:37 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: 1966 Floor Pans
Well, first of all, you can't get a full floor pan with the hump in the door. So, yeah, you need to buy the separate floor pans and hump then weld them in inside the car. Bead welding is the preferred method, then use sealers for the cracks. However, if it were mine, I would lay down a bead on the entire connection. On EDIT: I see this is your first post here. Welcome to the site.
Old May 17, 2005 | 11:37 PM
Syntax's Avatar
Syntax
If you want a full floor pan check the link. But there expensive.
http://www.paddockparts.com/Paddock/...B711E662DD1482
Old May 18, 2005 | 08:03 AM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, usually the humps are still good to go, and most guys just put in new floor pans. Use seam seal on them after you get them installed and before you paint them.
baddog671
Jul 26, 2016 01:20 PM
b8checker
Oct 8, 2015 12:55 PM
UrS4
Oct 3, 2015 06:23 AM
b8checker
Sep 30, 2015 07:11 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
