5 lug swap on '66
Old Sep 14, 2008 | 10:44 PM
jmstang66's Avatar
jmstang66
Default 5 lug swap on '66
thinking of doing a 5 lug swap on my 66..but i wanted to know how hard it was (if anybody has done it) and what all i would need to get to do it?
Thanks--Jeremy
Old Sep 15, 2008 | 05:10 AM
kalli's Avatar
kalli
if you have 4 lugs all around then it's probably a 6cylinder mustang or it has been one.
I have no idea if there are possibilities with conversion plates or similar.
I had a 6cyl that was upgraded to a V8, so I had to go down the upgrade route.
I installed disc brakes in the front www.discbrakeswap offers such kits. With those spindles in the kit you'll have 11" rotors and the 5 lugs you're looking for. For the rear axle the easiest way for you is probably pull a used 8" rear axle from the scrapyard or similar. as in the full thing (housing, diff, axles)
Old Sep 15, 2008 | 11:18 AM
jmstang66's Avatar
jmstang66
yeah she's a 6 cylinder...200 straight 6 baby
Old Sep 15, 2008 | 11:28 AM
kalli's Avatar
kalli
hmm. let's see what the others say so. I only know the upgrade route. Since you might not need to upgrade the rear to 8" you might have better options than changing the full rear...
Old Sep 15, 2008 | 12:40 PM
mat11089's Avatar
mat11089
You can buy spacer plates that turn the pattern into the 5 on 4.5 pattern..
Old Sep 15, 2008 | 11:12 PM
jmstang66's Avatar
jmstang66
for both front and back? where can i get something like that
Old Sep 15, 2008 | 11:28 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
you dont want that, buy the www.discbrakeswap.com kit for the front and then buy a 8 or 9 inch for the reardo it right and do it once
Old Sep 16, 2008 | 01:44 AM
Chaos13's Avatar
Chaos13
Default I went the disc brake swap route
I went the disc brake swap route. Using the link mentioned above is easier than going to the scrap yard to get the front right...trust me. I pulled parts from an old granada, then I had to have a machine shop fix one of the parts I pulled. After all that, I still ended up ordering some parts from the disc brake swap website. Retrospectively, I would either start with discbrakeswap.com, start with a V8 car, or buy a coil over kit.
The piece I'm still missing in my swap is a 5-lug spare. I may try to pick up a space saver spare from a local auto recycler.
Old Sep 16, 2008 | 12:03 PM
choppermike's Avatar
choppermike
I also did the Granada swap. I used the front spindles and hardware and also got the rear end from the same car including the drivesaft. The granada rear was a bolt in with the exception of the rear spring plates.
Old Sep 16, 2008 | 01:11 PM
kalli's Avatar
kalli
i checked around a it and it seems that it's easy to create 5 bot pattern to 5 bolt
pattern as you can have the holes offset, buit a 4-5 will always interfere which will ask for 2-piece design. That said if you want anything proper it might set you down 200$ front and the same rear. everyone seems to say as well that i tputs stress on the parts and might sheer ...
so it's either keep them 4 lug or if you need 5 bolts, then as before I recommend the discbrake swap for the front. WEill give you proper brakes and 5bolt at the same time.
for the rear i don't know but I'd say it should be easy to source a good 8" rear for a mustang ij the states
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Bokeo
Oct 10, 2015 08:28 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
UrS4
Sep 30, 2015 10:13 AM
