Help with 1966 brake lights
Old Sep 16, 2008 | 09:50 PM
LazyPJ's Avatar
LazyPJ
Question Help with 1966 brake lights
Hi All. I need help with my 1966 Mustang brake lights. I have running lights and turn signals, but my brake lights just don't work anymore. We replaced the switch and it didn't help. What else couple it be?
Any ideas?
Old Sep 16, 2008 | 09:58 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
bulbs there are 2 elements you know
Old Sep 16, 2008 | 10:03 PM
1965fastback's Avatar
1965fastback
Wiring going to rear.
Old Sep 17, 2008 | 03:07 PM
jlg2002's Avatar
jlg2002
The brake lights are also the turn signal bulb elements. if you have turn signals but no brake lights, and you've confirmed the brake switch is functional, the Turn signal switch is bad.
Old Sep 17, 2008 | 07:20 PM
jamieNerikas66stang's Avatar
jamieNerikas66stang
i had this problem and check the ground wire coming from the tail light to the body,...mine was so brittle and broken, i regrounded them both and it worked! also make sure you have the correct bulbs
GPR
Dec 16, 2015 12:21 PM
DoctorScary
Sep 9, 2015 07:53 AM
Sep 8, 2015 11:50 AM
amandahchase
Sep 3, 2015 10:09 AM
