THE OFFICIAL BB/SB THREAD
Old Sep 25, 2008 | 01:41 AM
andrewmp6's Avatar
andrewmp6
Yes the m is a small block but its kinda a mutt.Ford did make a 302 cleveland but in aus only and you forgot the boss 302 and 429 which are way different them the normal ones.Also things like the cobra jets and super cobra jets.
Old Sep 25, 2008 | 06:23 AM
73 Sportroof's Avatar
73 Sportroof
FE Block;
352, 360, 361, 390, 391, 410, 427, 428.
I think I am still missing one.
Old Sep 25, 2008 | 08:23 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
actually there is no such thing as 400m!! most people incorrectly name it as such since visually it looks the same as a 351m..it is just a 400 correctly named
http://www.fordcobraengines.com/Modified%20History.htm
Old Sep 25, 2008 | 09:28 AM
Norm Peterson's Avatar
Norm Peterson
Originally Posted by 73 Sportroof
FE Block;
Two that I know of
332 and 406
Norm
Old Sep 25, 2008 | 10:08 AM
retro77's Avatar
retro77
Do you want to differentiate an FE from a big block? They are different. The smallest/first FE was the 352 [as stamped on all FEs on the front driver side]
Old Sep 25, 2008 | 11:12 AM
Norm Peterson
I find the 332 referenced in at least three places as an FE (and differing from the 352 primarily by the 0.200" stroke difference). And I missed a few related truck engines.
Originally Posted by http://www.mustangandfords.com/techarticles/15999_fe_quick_facts/index.html
The FE engine story isn't as complex as you might imagine. There were only nine displacements--332, 352, 360, 361, 390, 406, 410, 427, and 428 cubic inches. There was also a family of medium- and heavy-duty truck engines based on the FE series of engines called "FT," which stands for (you guessed it) Ford Truck. The FT engine family included the 330ci HD and MD, 359, 361, 389, and 391ci. There is some interchangeability between the FE and FT, but one has to be careful in a quest for parts because the FT looks virtually identical to the FE externally. Though a lot of internal parts look the same, there are important differences we will get into later.
FWIW, in other Ford engine families, post-flathead
385 engines
370
429
460
514 (SVO only)
MEL engines
383
410 (4.2" bore, not the FE 410 with 4.05" bore)
430
462
Y-block
239
256
272
292
312
Norm
Old Sep 25, 2008 | 11:19 AM
Norm Peterson
Here's a link to a better list. You just have to keep the "engine family" in mind rather than "SB/BB".
Link
Norm
Old Sep 25, 2008 | 12:54 PM
Jaded's Avatar
Jaded
Here's a link to the history of the 351M\400:
http://www.projectbronco.com/History..._ford_351m.htm
Old Sep 25, 2008 | 02:02 PM
SJs 66coupe's Avatar
SJs 66coupe
Originally Posted by Starfury
Yes, it's generally accepted as 'modified,' however some people refer to it as 'midland' for some reason I'm unaware of.
Was there a plant in Midland Michigan at one time?
Old Sep 25, 2008 | 02:17 PM
4reboy's Avatar
4reboy
I've always wondered, what exactly does FE stand for, and what is the difference between an FE and a BB
I do realize that Fe is the symbol for Iron, so does it just mean the FE blocks are iron? but aren't the BB's iron as well?
all so confusing
