THE OFFICIAL BB/SB THREAD
Old Sep 25, 2008 | 02:46 PM
  #21
retro77's Avatar
retro77
Good scoop here...also I stand corrected on the 352 being the smallest:
http://en.wikipedia.org/wiki/Ford_FE_engine
Also not sure on how accurate this info is:
"FE stands for "Ford/Edsel"
ref: http://www.clubcobra.com/forums/show...d=60889&page=2
Old Sep 25, 2008 | 02:48 PM
  #22
Norm Peterson's Avatar
Norm Peterson
FE = Ford Engine
FT = Ford Truck
(http://www.mustangandfords.com/techa...cts/index.html)
MEL = Mercury-Edsel-Lincoln
I'm pretty certain that (with the exception of the current 4.6L 3V engine) all Ford production V8 blocks have been iron.
Norm
Old Sep 25, 2008 | 04:35 PM
  #23
THUMPIN455's Avatar
THUMPIN455
Yes you need to differentiate the families, not just the CID. With Fords its all about the architecture and vintage, there are some that have design elements that fit other families while having their own distinct design attributes.
When designating big block or small block, a good measure is bore spacing, how far apart the center lines of the bores are from each other. Ford built a vast array of engines, some are amazingly interchangeable like the FE series. Often a displacement increase is only a crank, and piston swap to the next higher one. ie 360-390-410, and even the 429 and 460 share the same bore with only the crank and pistons being different.
I dont concern myself with what the designations stand for, be they FE, or M, or whatever. I just use them to identify what goes where. The flathead bowed out in something like 1952, the mod motors came out in 1992 with all pushrod V8s being gone by 1996, give or take. So over 40+ years Ford built different engines for different purposes, and they have their own internal systems that we are not aware of as consumers.
What I do concern myself with is what fits what, and from what years. In the 302 engine there are distinct variations with limited interchangeability between them. Knowing what years had what crank is more than helpful or merely trivia, it prevents you from buying something you cant use. Also you can find out what it takes to make your 390 into a poor mans 428 provided it can take the overbore.
I have found three different small block bellhousings just since 1964 for the C4 transmission. That doesnt include C5, C3, FMX, or C6 transmissions, only the C4. Not evry C4 is the same either, there are year breaks, different valve bodies, different oil pans, different pumps, different this different that all throughout the years they were made.
Sometimes its a matter of see if it fits when you dont know where it came from or what it came with. Knowing what years fit and interchange even being different isnt easy with no hard and fast rules. Ford did mid year changes on everything, more than a few times multiple changes during a year.
The one thing that doesnt change is bore spacing. All the W, C, and M engines share the same bore spacing. The 335 series is all unto itself, as is the FE series. The M is the largest and heaviest small block with canted valves like the 335 and shares the bellhousing pattern with the 335, but its a small block that easily swaps into where a 460 was and vice versa.
Ford probably did that so they could use fewer parts on the assembly line to save money. Using the same engine mounts, same transmission case, and whatever else they could between them saved them money in a time that was a belt tightening recession. Something GM and Chrysler had been doing for years as standard operating procedure, not that everything they made was the same either.
No matter if its a big block a small block or a Y block, its a Ford and it probably wont fit much other than what it already is.
At least people have realized that the Cleveland and M engines are small blocks. I wonder where that moron that thinks an FE isnt a big block is these days...
Old Sep 25, 2008 | 04:47 PM
  #24
urban_cowboy's Avatar
urban_cowboy
Originally Posted by 4reboy
I've always wondered, what exactly does FE stand for, and what is the difference between an FE and a BB
I do realize that Fe is the symbol for Iron, so does it just mean the FE blocks are iron? but aren't the BB's iron as well?
all so confusing
FE = F***ing Expensive
Old Sep 25, 2008 | 04:56 PM
  #25
67BullittCoupe's Avatar
67BullittCoupe
um is the 351 cleveland a big block? does it not use a diffrent block than the windsor? dosent it use the 331 351 and 400 family block?
just wondering
Old Sep 25, 2008 | 05:53 PM
  #26
retro77's Avatar
retro77
More infor for you:
http://www.compcams.com/Technical/Ford/TechInfo1.asp
Old Sep 25, 2008 | 07:58 PM
  #27
67BullittCoupe
cool link^^^^
Old Sep 25, 2008 | 09:16 PM
  #28
boss_dude_429's Avatar
boss_dude_429
hey what about the 225 and the 221 and if were counting, the 281
Old Sep 26, 2008 | 05:41 AM
  #29
Norm Peterson
255?
(closest to 225 is probably the 223 CID inline 6)
Old Sep 26, 2008 | 08:08 AM
  #30
boss_dude_429
sorry guess i just got them mixed up, anyways what about the 221 and the 281! anybody got any history on them?
