Power Steering Question
Old Sep 29, 2008 | 12:28 AM
pimp2303's Avatar
pimp2303
Default Power Steering Question
Will a 1969 Mustang Power Steering Set Up fit on a 1967. if so will it be any fabrication work needed.
Old Sep 29, 2008 | 03:28 PM
jlg2002's Avatar
jlg2002
According to the NPD catalog, they show 67-70 as the same cylinder and most of the other parts. Put together a system using an online catalog and look for part number differences.
Old Sep 29, 2008 | 04:59 PM
stanger53's Avatar
stanger53
Yes it will.
There is a slight difference in the bend of the centerlink where the idler arm connects, but it is close enough to interchange.
If you have a 67 with the 1" sector shaft steering box, you will need to use a 65-66 V8 pitman arm. If you have the 1.125" sector box, then any 1968-1970 PS pitman arm will work.
The 67 came from the factory with a 1/4" pressure port on the control valve. If you use a 69 setup, it will have a 5/16" port. Use the 1968 pressure hose and it will hook up properly.
Tivo304
Aug 28, 2023 12:19 PM
zanemoseley
Sep 6, 2015 12:58 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
