Keep Original or Replace Engine
Old Oct 7, 2008 | 07:17 PM
  #21
tomnardozza's Avatar
tomnardozza
i used to think "keep all the original parts just in case", but really....you convert your car to an 8 cylinder....scrap the 6. nobody wants 'em, nobody's gonna want 'em, and for originality?? your car was originally a 6 cylinder mustang... convertible or not... you keep shelby's and hipo's and mach's and boss's original because they're worth so much. you do whatever you want with an original 6 cylinder car. that's the beauty of owning a car like yours. you don't have to be **** and save everything and have the "paint ok" stamp in the right place and...... you can do what you want without ruining the value of what you have, a cool classic Mustang.
Old Oct 8, 2008 | 10:41 AM
  #22
1971mach1's Avatar
1971mach1
Originally Posted by cxr
where can i find info on turbochargers on an I6... my backyard brother in law mechanic says he never installed a turbo.
but i need more horsepower with fuel efficiency to get over that 405 everyday.
Check in your area for racing shops that install turbos.
I wouldn't try to install a turbo yourself (or your brother inlaw). Stick to headers, intake and a bigger carb, there are already kits for the I6 and i hear they give good results.
Some info on turbo 6s:
http://www.mclearranracing.com/index.html
Old Oct 8, 2008 | 12:25 PM
  #23
1slow67's Avatar
1slow67
ROTM Moderator
6 cyl mustangs are rare. In 67 about 30% of mustangs were 6cyl. That has been lowered due to the people that swap the engine. In 68 there were about 29%. Those are less also.
Old Oct 8, 2008 | 03:12 PM
  #24
tomnardozza
there are 2 factors in determining value. rarity and desirability. the reason that only 30% of 67's are 6's is because everybody wanted an 8. i'm not bashing the ol' 200, but fact is, a 67 6 cyl will never be more desirable than an 8.
Old Oct 8, 2008 | 03:43 PM
  #25
Carlos Pineiro's Avatar
Carlos Pineiro
1. Keep the 6, no matter what.
2. One option: Keep the 6 in your garage and drop a small block V8 in your car.
3. Another option: Keep the 6 in the car, and build hp & torque around it.
4. And of course: Opt to do nothing. Drive it like it is.
If you opt for a V8, remember that your wheels, brakes and suspension may have to be modified as well.
A turboed 6 will not beat a V8.
Think about how you will actually drive the car. Gas usage might be important, etc.
Good luck. Please don't separate ownership of the 6 with the owner of the car.
CP
Old Oct 8, 2008 | 03:59 PM
  #26
69FB's Avatar
69FB
When I bought my car I thought it was a Mach 1 at first with a 351W. I found out shortly after that it was just a plain sportroof with a modified 302 (yeah I know I'm not mechanically inclined).
Now if it had been a Mach 1 with the original engine I probably would have been careful on what I changed out.
Knowing now that it's a regular sportroof and ALOT of things are far from original (or even ford products) I'm going to restomod it b/c I will be able to enjoy it more.
I'm all into protecting/perserving history, but if you're wanting to drive and enjoy it do what you want with it.
Old Oct 8, 2008 | 04:53 PM
  #27
1971mach1's Avatar
1971mach1
CP
Huh? there are production 4 and 6s that will beat v8s, Porsche turbo carrera is a v6 is one example.
Many race cars, like formula and champ series are 4 and 6 cylinders.
They're often over 700hp.
It all depends on how much boost you give it, and how well your engine can take it.
This website builds Ford inline 6s with turbos for drag racing:
Old Oct 8, 2008 | 08:15 PM
  #28
1slow67's Avatar
1slow67
ROTM Moderator
I was talking with my grandfather and he had 6cyls that would beat 6-pack V8s. 6cyl engines have more torque than a V8, so off the line a 6cyl would win.
Ex of fast I6/
63 Falcon I6
Time 1/4mile: 10.95@124
engine and mods: 250ci, T4 Turbo, 274H, CI Aluminum Head, Holley 600, C4 trans, 3:50-9"
Old Oct 8, 2008 | 09:01 PM
  #29
JHPSTANG's Avatar
JHPSTANG
Default Keep it!
I just spent about an hour getting to know my I6, and I'm keeping it! I'm no mechanic, and I'm also no dragster, so for cruising with the top down, gas mileage, and simplicity of repairs so I can actually keep cruising, I'm glad my car has a 6. I just made a list of everything (?) I need to get it running. Now it's off to the catalogs!
Old Oct 8, 2008 | 11:18 PM
  #30
Carlos Pineiro
Thanks for the info. Of course you can easily produce significant HP with a 6 if you work on it so you're right.
CP
