View Poll Results: Paint or motor
Paint It
72.97%
More HP!
27.03%
Voters: 37. You may not vote on this poll
cant decide
Old Oct 8, 2008 | 10:34 PM
  #21
guybored's Avatar
guybored
How's the engine? It looks great the way you have it set up, by the why what are the size of the back rims. If I where you I would paint it first. that's what I did. paint first then the engine, not there yet but hopefully soon. by the way I have a 200cid and I would like a 5.0 but it moves run's ok just needed some paint. Whats the reason you want to update the motor? just cause or is yours in a bad state. If the engine is not so good then I would go for the engine first but I guess it all depends on you. Well good luck in what you decide and if you go for the paing(hint) let us know how it comes out.
Old Oct 8, 2008 | 10:36 PM
  #22
Tang 72's Avatar
Tang 72
I say there is a awesome factor to any car that looks rough and can walk most everything else on the road... i say go motor every time...
Old Oct 8, 2008 | 10:53 PM
  #23
fakesnakes's Avatar
fakesnakes
Paint first, you have a pretty stout engine already. Plus, I would rethink buying an engine from T&L.
Old Oct 8, 2008 | 10:59 PM
  #24
fakesnakes's Avatar
fakesnakes
Oh, yes, on T&L here is why:
http://www.gt40s.com/forum/feedback-...y-control.html
There are similar posts on other forums.
Old Oct 8, 2008 | 11:26 PM
  #25
REAVER117's Avatar
REAVER117
If you've got a new cam, intake and set of heads, why not just get a stroker kit and install everything on the current block?
Old Oct 9, 2008 | 02:32 AM
  #26
MonsterBilly's Avatar
MonsterBilly
I second Reaver! You will need to remove the engine for proper paint. while it is out buy the stroker kit (go with a name brand kit) get the block machined and assemble the engine. it should be perfect timing!
You will be able to afford both if you do it this way. And you will learn a little more about the internals.
Old Oct 9, 2008 | 10:24 PM
  #27
eZ's Avatar
eZ
Engine is brand new pretty much...just a 5.0 roller block 300hp. Rims out back are 18x9.5. My motor is in great shape. Its just that ive built the rest of the car to handle a lot of hp. I have a strong aod, a 9'' detroit locker with 4.11s, and a martz rear 4 link suspension with a mini tub
As far as the motor tandl was going to do the assembly for me. Just ship them my parts and my total out of pocket after i sell my motor is 2500.
Paint is going to cost me 5-6k
Reaver117
I dont have the know-how to build a motor myself
Old Oct 9, 2008 | 11:51 PM
  #28
68EFIvert's Avatar
68EFIvert
Reaver117
You can learn how to build an engine. The first engine I built is in my mustang. It injected and blown and the biggest worry I have is will the block crack. Get yourself a book and go very slowly.
Old Oct 10, 2008 | 05:46 PM
  #29
kalli's Avatar
kalli
i would have vodet HP until I saw the pic. paint!
Old Oct 10, 2008 | 08:34 PM
  #30
eZ's Avatar
eZ
ok ok...ima start shopping for paint next week. I already started stripping the car today.
