Better Cooling
Old Oct 12, 2008 | 05:16 PM
eZ's Avatar
eZ
Default Better Cooling
So I cut open my radiator support on my 65. Fit a 24'' aluminum radiator. Had to relocate battery to the trunk, customize some hoses, and run new tranny cooling lines. Car runs much cooler now. No more overheating. Next im installing a taurus fan.
Attached Thumbnails Better Cooling-img_1279.jpg   Better Cooling-img_1288.jpg   Better Cooling-img_1285.jpg   Better Cooling-img_1286.jpg
Old Oct 13, 2008 | 07:16 AM
musnicki's Avatar
musnicki
Nice set up. It's always nice to be able to pull up to a red light, car sounding all nice, having people wave at you and drool over your ride and not have to worry about the car temp at the red light.
I like that thick fan belt that you have, oh and don't forget the fan shroud. I think when you remove the fan from the water pump you'll have to get a set of shorter bolts to bolt the pulley back onto the water pump, or just get a dremmel and chop off the ends like I did to get your belt pulley back on with out the bolts sticking out.
Old Oct 13, 2008 | 12:23 PM
Carlos Pineiro's Avatar
Carlos Pineiro
Nice work. I have the same K&N filter w/a functional scoop. It rocks.
If you have AT and you don't already have a tranny cooler, get one. They're $50-$80 bucks and a snap to install. Your AT fluid will be bright orange forever.
CP
Old Oct 13, 2008 | 12:45 PM
eZ's Avatar
eZ
ran into a probem with my electric fan. its a lil too deep and it contacts the water pump. im going to trim it today and try again tomarrow. as far as a tranny cooler the radiator has a built in tranny cooler.
Old Oct 13, 2008 | 12:47 PM
eZ's Avatar
eZ
mare the fins on all aluminum rads this easy to bend? ive bent the hell out of mine.
Old Oct 13, 2008 | 02:17 PM
Iskwezm's Avatar
Iskwezm
you could get a "fin comb", but i just use a small screwdriver to striaghten mine.never perfect but better.
Nice job!i had to trim my fan too.MAKE SURE YOU PUT A STRAIGHT EDGE ALONG THE SHROUD TO CHECK IF THE CLIP THAT RETAINS THE FAN DOESNT PROTRUDE. (and dont spin it to check, its sharper them a knife )Mine rubbed a hole in a row last week(after 2 years), a little JB weld and crimped the hole shut(the size of end of grain of rice).
where you from???
Old Oct 13, 2008 | 02:53 PM
eZ's Avatar
eZ
im in anaheim hills off weir canyon
Old Oct 13, 2008 | 02:58 PM
Iskwezm's Avatar
Iskwezm
OH, your about 20 minutes from me, im a little passed Brea.
BOB ROME
Jul 26, 2023 01:54 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
MusicCity615
Sep 12, 2015 07:05 AM
