engine dies under high g forces.
Old Oct 14, 2008 | 10:57 PM
Gun Jam's Avatar
Gun Jam
what would be hard to do? Adjust float level? wouldn't bending the arm on the float so that the float set closer to the carb base when held upside down increase float bowl volume?
-Gun
Old Oct 15, 2008 | 11:16 AM
cprstreetmachines's Avatar
cprstreetmachines
It can be tough on some models of carbs because the vent tubes don't stick out very far. Not much to slip a hose on.
Old Oct 15, 2008 | 11:26 AM
tyler72's Avatar
tyler72
You can only do the rubber hose deal on Holley style carbs. This isn't possible on Edelbrock/Carter Carbs. And that only helps if fuel is overflowing out of the vent tubes, which is an unlikely situation here. Raising the float level by bending the floats slightly should do the trick.
Old Oct 15, 2008 | 01:41 PM
Gun Jam's Avatar
Gun Jam
Can anyone confirm that bending the floats upwards (so distance between top of carb and floats is less) will increase fuel volume?
-Gun
Old Oct 15, 2008 | 01:54 PM
Norm Peterson's Avatar
Norm Peterson
Has to.
It means that the depth of the fuel has to be greater in order to make the float shut the inlet needle against its seat.
Norm
Old Oct 15, 2008 | 02:14 PM
Gun Jam's Avatar
Gun Jam
excellent that's what I thought. Sometimes things start out black and white and what should real simple starts to become complicated the colors start to run and what was once a clear picture has become gray and foggy.
I only want to take this thing apart once.
-Gun
Nick Oliver
Oct 17, 2018 04:22 AM
StalkerGT
Sep 25, 2015 02:41 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
Mobiusone stang
Sep 7, 2015 08:46 PM
5.0 kevo
Sep 3, 2015 06:24 PM
