Holley Carb question w/pics! (kinda large)
Remove that bolt, and put a lighter spring in. You also in all likelihood need to lean out the accelerator pump. The fact that you can mechanically open the secondaries and not bog indicates the pump shot was far too rich to begin with. It was too much for just the primaries, but is ok for all 4 barrels.
In other words, the carb wasn't set right.
loads of good explanation here
my take on this is: if you have to manipulate your carb to have it run better then something was wrong in the first place. so yes. change the carb back to original and go from there
Daddys Girls GTs
Sep 14, 2015 08:46 PM
jaiidutch
Sep 14, 2015 10:29 AM
