oil pressure question
Old Oct 25, 2008 | 07:13 PM
az1966's Avatar
az1966
Default oil pressure question
I have a 66 coupe, 200 ci motor, 3 spd manual tranny,,,,lately the oil pressure guage has been sitting at a hair lower than the half way mark and as the motor warms up the guage starts sinking to about the 1/4 mark ( hot as all get out in Phoenix arizona),, I understand oil thins out as it warms up, but I'm using 10-40 valvoline synthetic oil, needless to say if if drops to far it's a disaster,, question is is how far is to low? should I switch to 20-50 weight,,, the low end of the motor has never been rebuilt and I'm thinking oil pump replacement,, no knocking or rattling yet,,, any input would be appreciated
Old Oct 25, 2008 | 08:04 PM
67 evil eleanor's Avatar
67 evil eleanor
You may want to try a mech gauge to see what the pressure actually is, and its not a gauge or sender issue. I like synthetic oil in an older engine. It has been my past experience though to see a slight drop in pressure when switching from dyno to synthetic. Even with the same viscosity. I'm not sure why.
Old Oct 25, 2008 | 08:56 PM
1965fastback's Avatar
1965fastback
Either your pump is bad or as evil sad, your gauge is bad.
Old Oct 25, 2008 | 09:00 PM
Gun Jam's Avatar
Gun Jam
or some several components are not fitting as tight as the use (worn out) and thus causing a drop in oil pressure.
+1 on switching to a mech gauge.
-Gun
Old Oct 26, 2008 | 08:11 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
Drive a Chevy. Their oil pressure is all over the place.
I wouldn't worry about it. It's an old motor that's loosened up.
As long as you have some pressure at idle, and more when you step on the gas you're okay. The general rule of thumb is 10psi for every thousand RPM.
Worry if you have NO pressure.
Old Oct 26, 2008 | 08:40 PM
1965fastback
Hey now, my truck's oil pressure is steady and it's a 76 Chevy.
Tivo304
Aug 28, 2023 12:19 PM
StalkerGT
Sep 25, 2015 02:41 PM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
cbird1177711
Sep 2, 2015 08:51 PM
