8" installed, yoke question
Old Oct 27, 2008 | 12:29 AM
350kmileFord's Avatar
350kmileFord
Default 8" installed, yoke question
I took out my stock 6 cyl rearend this evening and put in the 8". Now I have a V8 driveshaft and I know it does need to be cut, about an inch.
I also noticed/realized that the V8 yoke is a bit longer. However, it is the same spline. The V8's internal splined length is the same, but the yoke itself is longer. There is an extension of the yoke tube past the splines. Does this make sense? I assume it will to those that have done the swap... Now the question is, do I need to get the yoke cut down as well? Seems like a reasonable answer.
HOWEVER, I have a T5 that will be installed within the next year, and it seems to fit into that perfect. When I put the V8 yoke in my currently-installed automatic, however, it sticks out a bit far (due to the extra long yoke housing)
Do I just need to have it cut down now so I can install it on the automatic, and then find another, uncut one when I got to put the T5 in?
Everything is installed, brakes are bled, and I'm ready to go to the driveline shop tomorrow . . I just need some info here.
Old Oct 27, 2008 | 07:20 AM
Gary H's Avatar
Gary H
How far in are you putting the yoke? Not all the way I hope, it needs room to slide in and out as the suspension moves. IIRC you need 1 1/2" of travel, call the driveline shop to be sure.
Old Oct 27, 2008 | 04:32 PM
kalli's Avatar
kalli
just read the PM. unfortunately i don't know about the slip yoke bit as I installed T5 in mine. Sorry
Old Oct 27, 2008 | 09:15 PM
photocliff's Avatar
photocliff
IS there a shorter yoke available?
Old Oct 27, 2008 | 10:45 PM
350kmileFord
Well I dropped it off at the driveline shop today. I'm just having them cut it down. No reason it shouldn't work.
drfister
May 3, 2018 10:38 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
toastintx64
Aug 29, 2015 05:12 PM
whatsup62
Aug 29, 2015 01:25 PM
Shifty Magoo
Aug 25, 2015 03:08 PM
