autometer gauges.
Old Oct 29, 2008 | 12:19 AM
adutch06's Avatar
adutch06
Default autometer gauges.
Im intalling a short sweep oil presure gauge and temp gauge under the dash somewhere. Ive heard that all i have to do is replace the sending units in the engine compartment and hook up the original wires but how do i wire the gauges inside the car. Do i just splice into the excisting wires on the gauge cluster? Is it possible to have the stock gauges in my 65 mustang work along with the 2 autometer gauges? Please let me know.
By the way. My car is a 1965 mustang with a 302 4 barral motor out of a 1968 with a t5 tranny. It has a big cam in it as well.
Old Oct 29, 2008 | 03:21 PM
jlg2002's Avatar
jlg2002
Typically electrical gauges need the correct input sensor (senders) on the engine. Review the Autometer requirements before you order them. Most aftermarket gauges need +12v for one side of the gauge and the sender on the other, so no, you can't use the existing wiring. Yes you can use the gaugers in parallel but you need to wire them that way ( 1 wire to +12 and 1 wire to the sender, posibly a third wire to ground depending on the gauge)
Iskwezm's Avatar
Iskwezm
Yes, both can work.The oil pressure port will need a "T" for both senders and the manifold should have 2 ports for the temp sender.
Fallstar01
Sep 30, 2004 04:31 PM
nnhockey18
Sep 13, 2004 07:06 PM
Moosetang
Aug 23, 2004 01:04 PM
88SaleenStang
Jan 11, 2004 11:34 PM
Black92LX
May 4, 2003 02:58 PM
