Radiator
Old Nov 3, 2008 | 05:43 PM
NoWhrMn's Avatar
NoWhrMn
Default Radiator
So while replacing the water pump on the 66, I slipped and put a hold in the radiator with my slotted screwdriver (what a dumb a$$). What is the best option for replacement/repair? Is repair worth it, or is it best just to buy a new one. If replacement is one place better than others??
Old Nov 3, 2008 | 05:48 PM
Gun Jam's Avatar
Gun Jam
where was it punctured?
In solid base or in the core around the fins?
They can be soldered pretty easy if you can reach it.
-Gun
Old Nov 3, 2008 | 05:50 PM
NoWhrMn's Avatar
NoWhrMn
I am not exactaly sure. I didn't let it continue to spray for very long.
Old Nov 3, 2008 | 07:07 PM
NoWhrMn's Avatar
NoWhrMn
Default Transmission Cooler lines on Radiator
Does anyone know what size caps the transmission cooler lines on the bottom of the Rad are? I am in the process of removing the rad and I don't want transmission fluid all over the garage.
Old Nov 3, 2008 | 07:34 PM
1965fastback's Avatar
1965fastback
Duck tape. Yes it will work for anything.
Old Nov 4, 2008 | 04:00 PM
musnicki's Avatar
musnicki
JB Weld for the win!!!!!!!!
Old Nov 4, 2008 | 04:24 PM
racin66coupe's Avatar
racin66coupe
yeah, JB weld that beast, works wonders. used it on many race cars
Old Nov 4, 2008 | 08:39 PM
Iskwezm's Avatar
Iskwezm
yep, easy and fast
My fan for some reason rubbed a whole on a row on mine on the way back from a car show.Pulled the radiator,opened the whole(size of a grain of rice)stuffed in some JB weld then pinched it shut(it was only the edge)I know its not the best way to fix it, but i was in a jam and I probably wont weld it unless it leaks again.
Granatelli Sales
Jan 20, 2020 12:34 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Beerman309
Sep 19, 2015 01:16 AM
MusicCity615
Sep 12, 2015 07:05 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
