Metal bumping question?
Old Nov 3, 2008 | 07:58 PM
green_blurr's Avatar
green_blurr
Question Metal bumping question?
I was slowly working a small dent out of my roof about 4" in diameter with a hammer and dolly. I managed to pop it outward convex, i pressed down again to straighten it out and it poped back in concave i can press it back out and make it concave to match the roof with my hand. so the question is do i leave it concave and use body filler? or make it convex and use filler? i dont want it to pop up or down. ?
Old Nov 3, 2008 | 09:08 PM
fakesnakes's Avatar
fakesnakes
You got yourself an oilcan dent. What has happend is the metal stretched. You need to use a shrinking hammer and work it back to normal. If you don't, temperature changes will cause any filler to pop out over time.
Old Nov 3, 2008 | 10:24 PM
green_blurr
oil can dent so i can use a acetelyne torch and shrink it back to normal or do i have to use a hammer and work with it?
Old Nov 3, 2008 | 10:29 PM
fakesnakes's Avatar
fakesnakes
You can use a torch if you have real skills. A torch can cause more damage than it repairs. On the roof any distortion is hard to fix and easy to see.
Old Nov 3, 2008 | 10:42 PM
green_blurr
Well il give it a shot i cant afford to have my paint job ruined. il just heat it up slowly and pop it back with a wet rag and try to hammer and dolly it back smooth.
Old Nov 3, 2008 | 11:29 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
try shrinking it with a shrinking hammer or a hammer with a pick end
Old Nov 4, 2008 | 05:53 AM
MBDiagMan's Avatar
MBDiagMan
I agree with rmodel, but I would strongly prefer using a good shrinking dolly or hammer rather than a pick, but you have to use what you have on hand. The new shrinking dollies and hammers I've seen have a bunch of small pimples. The old ones have some larger serrations. The old ones with the serrations seem to work much better.
The torch approach is risky.
Good luck,
shrkbate
Oct 2, 2015 08:25 PM
Ghost_Conscience
Sep 23, 2015 02:17 PM
schecterplayer
Sep 23, 2015 08:38 AM
smiller38
Sep 16, 2015 07:59 AM
