front suspension install
Old May 27, 2005 | 02:50 AM
caballo66's Avatar
caballo66
Default front suspension install
i'm installing a new front suspension on my 66 GT and pretty much have it all done. the last step is putting the springs and shocks back in. what is the best way to go about getting the springs back in there? compress the spring, lower the lower control arm, put the spring in, jack up the lower control arm, bolt everything up including the shock and then release the spring? just seeing if there is an "easy" way to do it before i waste my time doing it the wrong way or possibly hurt myself. the coil spring perch should probably be able to pivot back and forth, right? i got scott drake parts and the perches are pretty tight and don't move. do i need to get them looser?
thanks.
Old May 27, 2005 | 04:49 AM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: front suspension install
That's pretty much it. Just make dang sure you get the best spring supressor money can buy.
Old May 27, 2005 | 10:05 AM
68FastbackGT's Avatar
68FastbackGT
I second what Soaring said. A compressed spring can be a deadly bomb. Take great care in compressing them and handling them while they are in the compressor. If the spring compressor fails, bad things can happen.
Old May 30, 2005 | 12:37 PM
69mach1377's Avatar
69mach1377
I did not need a compressor for my 69 rebuild. IIRC, the trick was to let everything drop down and unbolt the top shock mount. There was no compression left in the springs...
Old May 30, 2005 | 01:45 PM
Soaring's Avatar
Soaring
I ♥ Acer
It's not for getting them out, but for putting them back in.
Old May 31, 2005 | 12:45 AM
69mach1377's Avatar
69mach1377
Uh...I agree sort of. Not only did I remove my springs, but I put them back in. No compressor was required.
drfister
May 3, 2018 10:38 PM
SYNY5TER
Sep 2, 2015 01:35 AM
Sep 1, 2015 08:16 PM
kawiguy827
Sep 1, 2015 07:09 PM
tmdm
Aug 7, 2015 10:24 PM
