AOD conversion question
Old Nov 15, 2008 | 09:04 AM
opie_803's Avatar
opie_803
I have read somewhere that there is a difference between the 80-87 and 88 on up AOD transmissions. Can someone tell me when they went AODE and what the other differences are.
Thanks.
Old Nov 15, 2008 | 10:32 AM
Norm Peterson's Avatar
Norm Peterson
Originally Posted by 71stang99
I was talking to the reps at PATC about the speedometer setup and they wanted to know the 'teeth' for the speedometer shaft on the tranny which I didnt know as I thought it would be standard, they told me to take the tail housing off to count them. Can I find this out without taking the tail section off?
I can think of a couple of ways that might work.
You may be able to count the number of "thread starts" if you can mark one of them and turn the output shaft exactly one turn. The drive gear looks like a normal thread, but it's really several separate threads twisted together. The number of separate threads is the "tooth count".
A variation would be to place the point of an ice pick or similar pointy thing in the very beginning of one groove. Turn the output shaft exactly once. Count the number of grooves between where the pick started and where it ended up. Include either the start groove or the finish groove, but not both.
Having a helper on hand might be useful.
You'll have to let us know if you can make either of those methods work. I'm just brainstorming a bit here.
Norm
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
