Engine Removal - Getting it together
Old Nov 15, 2008 | 02:03 PM
Chaos13's Avatar
Chaos13
Question Engine Removal - Getting it together
I am about to pull my 6 cylinder from my 65. I can't quite figure out how to connect the engine leveler to the block. I want to pull the engine and transmission together.
Do I need to buy a specific type of bolt to make this connection?
All suggestions appreciated.
Old Nov 15, 2008 | 03:28 PM
robert912004's Avatar
robert912004
you can either connect it to the intake bolts which you will need longer bolts or you can put two back by the trans and the other two up front... you might have to take the carb off....
Old Nov 15, 2008 | 03:29 PM
1965fastback's Avatar
1965fastback
Two strapes under the oil pan. It will work.
Old Nov 15, 2008 | 04:15 PM
WildMustang351's Avatar
WildMustang351
As long as you plan on replacing the oil pan gaskets and possibly the oil pan itself.
This would work but is not recommended.
I have always used a bolt at the front of the cylinder head and back of the cylinder head.Take the bolt out and insert a short amount of chain,put the bolts back in,then hooked the leveler to that.
Those bolts will be enough to pull both the engine and transmission at the same time and hold it.
Old Nov 16, 2008 | 07:18 PM
Chaos13's Avatar
Chaos13
Default Still scratching my head
Thanks for the replies. Being a complete rookie at this, I'm still a little unclear on how to accomplish the 6-cylinder removal. I prefer not to have to pull the cylinder head off to hoist the motor. However, I don't see any bolts/bolt holes on the outside of the block for connecting the chain.
If I connect to the manifold bolts, will the block pull to one side.
Pictures would be great if anyone has some.
Thanks!
Old Nov 16, 2008 | 08:48 PM
1slow67's Avatar
1slow67
ROTM Moderator
http://fordsix.com/forum/viewtopic.php?t=53884
He doesn't recommend doing it the way he did(3rd post), but you could try.
Granatelli Sales
Jan 20, 2020 12:34 AM
MusicCity615
Sep 27, 2015 12:53 AM
spamedic
Sep 9, 2015 12:15 AM
Gary Ugarek
Sep 5, 2015 09:03 PM
