disconnecting drivetrain for towing?
With an auto, need to disconnect the drive shaft as mentioned.
Why do you need to pull it out of the trans though? Just disconnect the
rear u-joint and tie the shaft up out of the way with bailing wire. Make sure it can't slip out of the trans though.
With a manual, just put it in neutral and start yer towing.
lincolnshibuya
Dec 8, 2015 04:37 PM
Sep 17, 2015 07:32 PM
TfcCDR
Sep 14, 2015 12:08 PM
1996, 66, diconnect, disconnect, disconnecting, drive, driveline, driveshaft, drivetrain, ford, manual, mustang, shaft, towing, trans
