Weight-Saving Upgrades
Old Nov 17, 2008 | 07:20 PM
guitarman376's Avatar
guitarman376
Default Weight-Saving Upgrades
Alright, i have a 69 mustang coupe with a 351w and fmx tranny.
Out of curiosity, about how much lighter will the car be if the following changes are done:
manifolds-headers
iron heads-aluminum heads
iron/steel accessories-aluminum accessories (such as water pump, new alternator, air cleaner assembly, power steering pump, etcetera)
stock suspension-Global West Negative Roll System front coilover conversion
stock interior-racing seats, steering wheel, gauges/gauge cluster, rear seat delete.
stock front end components-fibreglass hood, fenders, and other front fascia pieces (NOT fibreglass bumpers)
stock steering- rack and pinion steering
4 wheel drum brakes-4 wheel disk brakes from SSBC
stock driveshaft-aluminum driveshaft
FMX-built t5 transmission
stock wheels-aftermarket wheels (undecided on which ones)
I was thinking at least a couple hundred pounds (between 200 and 400lbs), would that be a good prediction?
Old Nov 17, 2008 | 07:33 PM
REAVER117's Avatar
REAVER117
The biggest gains will be from iron to aluminum parts and the T5 conversion. The T5 alone will shave off at least 100lbs, the FMX (nearly 200lbs) is a beast compared to the 75lbs T5. I'd say you'll drop 250lbs minimum.
Old Nov 17, 2008 | 07:46 PM
1slow67's Avatar
1slow67
ROTM Moderator
Depends on what aftermarket wheel. I have something like 90-93 OEM mustang rims and they weigh more than my originals did.
Old Nov 17, 2008 | 08:39 PM
67BullittCoupe's Avatar
67BullittCoupe
if you got money
steeda makes forged "ultralite" five spokes. in the 94-01 back spacing.
this will cut down wieght, but more importantly cut down significantly on rotating mass. which is a very overlooked part of performance
Old Nov 17, 2008 | 10:29 PM
guitarman376
Any other ideas? So 200-400lbs lost would be pretty accurate overall?
PaulH2
20
Jan 31, 2016 09:48 AM
jrrhd73must
Oct 2, 2015 09:17 PM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
UrS4
Sep 30, 2015 10:13 AM
