hows this motor?
Old Nov 23, 2008 | 12:50 PM
eZ's Avatar
eZ
Default hows this motor?
Looking at ebay...anything wrong with buying this. will the pistons be ok with afr 185's?
http://cgi.ebay.com/ebaymotors/SB-Fo...Q5fAccessories
Old Nov 23, 2008 | 01:03 PM
1965fastback's Avatar
1965fastback
I would buy it if it stayed below $750, it should perform like you want it to. As for the Afr's, I'm clueless. Good luck though!
Old Nov 23, 2008 | 03:59 PM
tyler72's Avatar
tyler72
Don't buy it unless you plan on running a blower or changing the pistions. The compression with the AFR 185s and those pistons would be in the low 8s. Not exactly what I would call a "performance" CR. Also, if you do build an engine with AFRs. Use the castings only... their springs, guides, and valves are absolute JUNK! However, the castings flow great, so as long as you build them with good parts you will be fine.
Granatelli Sales
Jan 20, 2020 12:34 AM
musnicki
Sep 23, 2015 07:11 AM
mustangchef
Sep 4, 2015 08:08 PM
Luke9222
Sep 4, 2015 06:46 AM
cbird1177711
Sep 3, 2015 08:43 PM
