Vacuum advance
Old Nov 24, 2008 | 04:10 PM
andrew340's Avatar
andrew340
Default Vacuum advance
I'm trying to replace my vacuum advance but i'm having a hard time getting the old one out. I opened the dizzy and undid the spring clip and lifted the arm off, and i've unscrewed the two screws, but it won't pull out. Is there something else holding it in?
Old Nov 24, 2008 | 04:34 PM
vescotech's Avatar
vescotech
Thats all that holds it. Sometimes one of the screws will break off and some of it will stay threaded in the dist. Check the screws to one another, they should be the same length. If the are pry it forward and off.
Old Nov 24, 2008 | 06:07 PM
kalli's Avatar
kalli
aye to that. there are screw hol;ding the canister and lot itself and then there is the arm that actuates the breaker plate.
Old Nov 25, 2008 | 12:15 AM
andrew340's Avatar
andrew340
that's my problem, one of the screws broke off, i just figured one was supposed to be shorter, whoops. thanks for the help
Old Dec 12, 2008 | 09:08 AM
andrew340's Avatar
andrew340
i've got 3 shims inside my vacuum advance, is that the same amount everyone else is using? 65 single point distributor
mrtrodonet
Sep 19, 2020 03:12 PM
baddog671
Jul 26, 2016 01:20 PM
marc954
Sep 29, 2015 11:18 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
TfcCDR
Sep 14, 2015 12:08 PM
