3/8" fuel pick up?
Old Nov 25, 2008 | 05:39 AM
fakesnakes's Avatar
fakesnakes
Default 3/8" fuel pick up?
Anyone know where I can get one for my 1966? I can only seem to find 5/16".
Old Nov 25, 2008 | 05:49 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
i know i added the larger 3/8 line like the shelbys. idr what size my sending unit was
Old Nov 25, 2008 | 07:19 AM
dodgestang's Avatar
dodgestang
http://www.quantaproducts.com/prodin...?number=SUF28B
Old Nov 25, 2008 | 08:11 AM
fakesnakes's Avatar
fakesnakes
Dodgestang comes through again! Thanks, man, order placed.
Old Nov 25, 2008 | 10:18 AM
dodgestang's Avatar
dodgestang
I have the same one in my car
I went to install my 3/8 lines and found out I had a 5/16 sender as well....also found out that Gastanks.com (quantas products) is 2 miles from my house in BFE Maryland! Who would have guessed it....and they had it in stock when I needed it.
Old Nov 25, 2008 | 12:14 PM
mustang3's Avatar
mustang3
I have a similar question. I have a 70 with a 302 and 4 barrel Holley carb that I am trying to bring back to life. I can't find anywhere what size fuel line I should run from the fuel pump to the carb. I suspect that I simply need to determine the size of the connections on the pump and carb. What size should it be for my set-up?
Old Nov 25, 2008 | 12:24 PM
fakesnakes's Avatar
fakesnakes
Regardless of what size you use, its effectiveness is only that of the smallest diameter line in the circuit. That would be 5/16".
This is why I asked the question. I have 3/8 hard line from the tank to the pump and from the pump to the carb. If I used the stock 5/16 pick up, my 3/8 line would be a waste. I have a 450HP small block. 5/16 is not quite big enough to provide the fuel flow required.
Old Nov 25, 2008 | 12:32 PM
dodgestang's Avatar
dodgestang
5/16 is more than enough for this setup.
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
svfetter
Oct 5, 2015 11:39 AM
b8checker
Sep 30, 2015 07:11 AM
mrappe
Sep 26, 2015 10:16 AM
uberstang1
Sep 20, 2015 06:42 PM
