Help with Driver window regulator PLEASE!!!
Old Nov 30, 2008 | 03:35 PM
Jforte13's Avatar
Jforte13
Default Help with Driver window regulator PLEASE!!!
Hey Guys, I was hoping you could help with my 68 coupe. My drivers side window is not going up or down. when i put the window handle onto the pin piece and turn it, it turns and makes a clicking noise. Do I need to replace the entire window regulator/scissors? If so...HOW the heck do i do that through the holes????? I am getting scared now. I have everything else under control on the car, but this is scaring me....i have been puttin this off, but need to tackle this now, i just don't really understand it....I have the interior book, and the "how to restor your Mustang" book, and neither are of any use at all. THANKS so much!
Old Nov 30, 2008 | 05:31 PM
MonsterBilly's Avatar
MonsterBilly
the door regulators are a one piece unit. They are about $60 new. with the door handels and window crank off remove the door panel.
you will find four bolts with star like washers on them. Just remove them. then remove the entire unit. You may need to put the crank back on and roll it up/down a little to get the rollers out of the tracks.
If you have a hard time getting the new one in then take off the other door panel and us it as a guide.
Old Nov 30, 2008 | 05:46 PM
Cogtx's Avatar
Cogtx
Not as bad as it looks...you do have to maneuver the regulator and scissor mechanism around...here is instructions from my 67 shop manual..
Attached Thumbnails Help with Driver window regulator PLEASE!!!-mustang-door-1.jpg   Help with Driver window regulator PLEASE!!!-mustang-door-21.jpg
Old Nov 30, 2008 | 07:33 PM
Jforte13's Avatar
Jforte13
Hey thanks a ton guys! thes jpegs are VERY helpful! I really appreciate it!
Old Nov 30, 2008 | 08:09 PM
JamesW's Avatar
JamesW
While I can't promise 68s are the same as 66...here's some info
http://www.midnightdsigns.com/james/Smooth%20Doors.htm
Old Nov 30, 2008 | 08:26 PM
Carlos Pineiro's Avatar
Carlos Pineiro
I'm not sure about 67 window regulators (don't remember), but in 69, the bracketed glass slides up and down 2 poles by way of a gear-driven scissor arm. The window bracket slides on the poles buffered by nylon glides.
This system was designed so that you wouldn't need to grease the poles. If you have this system (I think you do) with those little white plastic glide bushings, do not apply grease to the poles. Grease will attract enough dirt in a short time to make the window difficult/inoperable.
Unfortunately, no one makes these nylon glides, and old stock glides from the junkyard are just as worn (passenger side ones are always better). My windows would be a little less wobbly if someone made these things one day *sigh*.
Good luck.
Cp
cr620
Oct 3, 2022 10:18 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
jerrytubes
Oct 23, 2015 12:11 PM
TCStangerv6
Oct 11, 2015 05:57 PM
