Master Cylinder Question
Old Dec 12, 2008 | 07:07 AM
boeing747arowair's Avatar
boeing747arowair
Lightbulb Master Cylinder Question
I have a 66 coupe with power drums all around. I have replaced every part of my stock brakes system with new parts. Now I have a question about my master cylinder. Advanced Auto and Autozone have 2 master cylinders avaible for a 66 with power drums..One is specifed to be for a car built before 1/3/66 and the other is after that date. I would like to know any of you know what the difference might be. The only difference i see is the different caps. see below.
http://shop.advanceautoparts.com/pro...pe=230&PTSet=A
http://shop.advanceautoparts.com/Pro...pe=230&PTSet=A
THanks,
Old Dec 12, 2008 | 07:41 AM
MBDiagMan's Avatar
MBDiagMan
I don't know, but have you checked the build date on your car? It is on the number plate.
Old Dec 12, 2008 | 07:51 AM
fakesnakes's Avatar
fakesnakes
If no other reason becomes apparent, go with the later one. For all you know it was an upgraded part.
Old Dec 12, 2008 | 07:57 AM
boeing747arowair
thanks alot, i have not checked the dates because i have the doors in storage therefore figured some1 would know before going ahead and pulling the doors out. thanks though!
Old Dec 12, 2008 | 10:28 AM
JamesW's Avatar
JamesW
I believe the difference is with how the brake light connects.
Old Dec 12, 2008 | 10:44 AM
boeing747arowair
James, and if mine does not come equiped with that? My original just has the hard line coming out. No brake sensor light is attached. The other opening is plugged off.
Old Dec 12, 2008 | 12:06 PM
MBDiagMan's Avatar
MBDiagMan
I can't remember exactly where, but the date is stamped on the body somewhere. I think it might be on the top of the cowl on the passenger side.
Old Dec 12, 2008 | 12:30 PM
boeing747arowair
date is located on the driver door tag along with the color codes, axel, etc
Old Dec 12, 2008 | 01:27 PM
JamesW's Avatar
JamesW
Here's a photo of the 64 1/2 Master cylinder.... It has the brake light installed. If you do not have this, then you have the later model M/C.
http://image.mustangmonthly.com/f/94...mage_large.jpg
Old Dec 12, 2008 | 01:47 PM
boeing747arowair
thats correct james, i dont have the light. thanks
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
Luke9222
Oct 22, 2015 11:55 PM
treesloth
Sep 28, 2015 07:03 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
uberstang1
Sep 21, 2015 09:04 AM
