cam help please?
Old Dec 16, 2008 | 08:44 PM
racin66coupe's Avatar
racin66coupe
awesome. sometime after christmas ill start on this thing heads first most likely just so i know i have them. ive heard really good things about the voodoo line as well
Old Dec 16, 2008 | 08:47 PM
Starfury's Avatar
Starfury
You do realize this thing's going to be nearly undriveable without some really short gears, right?
Old Dec 16, 2008 | 08:59 PM
racin66coupe
how so? and what do you mean by short gears?
Old Dec 16, 2008 | 09:44 PM
Starfury's Avatar
Starfury
I mean you're basically going to have no power below 2k rpm, and little usable power below 3k. To get the car off the line you're going to need at least 3.73's out back. A TKO would be a good idea at some point to allow you to drive it on the freeway at less than 4500rpm
Old Dec 16, 2008 | 09:46 PM
racin66coupe
im thinking about 3.55's since it needs to be on the highway without spinning 5k lol
plus, just riding around town i dont need gobs of power unless i want it
Old Dec 16, 2008 | 10:03 PM
Starfury's Avatar
Starfury
No, but you need to get the rpm's up to make it driveable. My 331 is borderline with 3.25's, and my cam is a lot tamer than that one, AND it has Rhoads lifters to beef up the low-end. I really don't think you'll like driving it with 3.55's.
Old Dec 16, 2008 | 10:15 PM
racin66coupe
hmm.. is there a cam i could run that would make it more streetable? i was planning on using the rhoads lifters too... just get the cam, and not the lifters from lunati
Old Dec 16, 2008 | 10:40 PM
my77stang's Avatar
my77stang
i've heard alot of horror stories about the rhoades lifters, i seriously considered using them to help my bottom end but decided against it and ended up advancing my cam 4 deg (which i actually did to help idle vacuum) and i can tell it doesnt pull as hard to the 7k redline like it used to, but it helped on the bottom.
i was talking to him last night and suggested this crane z-series cam (new grinds), very similar to the lunati but a tad smaller. i considered this cam as well when i built my 289
http://www.cranecams.com/index.php?s...22&lvl=2&prt=5
i also think the lunati would work well though.
Old Dec 16, 2008 | 10:45 PM
racin66coupe
i should get more rpm with stiffer springs right? it does seem a bit more streetable
Old Dec 16, 2008 | 11:17 PM
my77stang's Avatar
my77stang
yeah you would, that may be the right answer for you. 130 or 140 lbs of seat pressure on the springs and you'll be able to wind it a little higher.
