cam help please?
Old Dec 19, 2008 | 10:02 AM
  #51
my77stang's Avatar
my77stang
wow that sure changed everything. its amazing on how much differential there can be between programs.
Old Dec 19, 2008 | 12:06 PM
  #52
urban_cowboy's Avatar
urban_cowboy
Well, the mistake I made is DynoSim will let you put in cam specs as either seat-to-seat timing/seat events or .05 lift timing/.05 lift events. Cam manufacturers state two different specs on cams (typically). One is "advertised" and one is ".05". Advertised for Comp is seat-to-seat, and since that is typically what I am dealing with I look at advertised only. Advertised for Crane is .004 which is NOT seat-to-seat. That can make a big difference and did in this case, so the safe way to talk about cams is from the reference point of .05 NOT advertised. I knew that and just missed it. If you tell a racer that you have a 280 duration cam, they will almost always ask what the .05 duration is because you cannot compare advertised durations among different cam manufacturers.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
