Please help!!!
Old Dec 22, 2008 | 10:55 PM
MonsterBilly's Avatar
MonsterBilly
Fakesnake is right on with that info. Do you have a prt # for that cam? I dont like the NPD catalog.
Old Dec 22, 2008 | 10:58 PM
1slow67's Avatar
1slow67
ROTM Moderator
Looked on NPD site and got this description for the cam. It says 289-302. But when you select the part number it gives you a different price and maybe a different cam.
CAMSHAFT, HYDRAULIC, SMOOTH IDLE, IMPROVED PERFORMANCE, ** NEW SPECS- DURATION 194 /204 @.050 , LIFT .424/.448, INTAKE/EXHAUST, 110 LOBE CENTER, 45 OVERLAP **
Old Dec 22, 2008 | 11:01 PM
MonsterBilly
I believe this is your part # 6250-1A
It states that it is for a 289/302 so the firing order should stay the same. If advancing it to 10* does not work then try a little more. My car will not idle lower than 18* advanced. this is due to my cam.
remember that it only takes small adjustments of the dizzy to change the timing a lot.
Old Dec 22, 2008 | 11:14 PM
MonsterBilly
if its not the timing then i bet $100 its the firing order. It is a common thing on for rebuilds.
Old Dec 22, 2008 | 11:21 PM
JMD's Avatar
JMD
My first thought is a vac leak also, if you have power brakes the big hose may be broken or leaking or the booster bay be broken.
Might be a manifold gasket, internal or external, or carp gasket or even a plug missing on the carb... I have seen the "missing plug issue" way more than I should have... (it is easy to leave the plug out of a new Edelbrock carb)
Old Dec 23, 2008 | 05:51 AM
Meadracing's Avatar
Meadracing
cam is Sealed Power CS-1158R
Old Dec 23, 2008 | 02:34 PM
Starfury's Avatar
Starfury
If your static timing is set right at TDC, that's your problem. The engine won't run like that. Try 10-12* BTDC, then move on to fuel/air adjustments.
Old Dec 23, 2008 | 02:53 PM
jlg2002's Avatar
jlg2002
Since you just put this thing together, you may have the valves too tight. if you can't find anything else wrong, pull the valve covers and give the rockers a 1/4 turn or so loosening.
Old Dec 23, 2008 | 06:36 PM
Meadracing's Avatar
Meadracing
Found it. The stock carberator spacer I used has grooves in the bottom and was hanging to far over the intake adn causing a big vacum leak. One new aftermarket spacer and new gaskets to care of idle. timing at idel is 5 degrees. What should it be. Now if I can find out where a tapping noise is coming from I be golden.
Old Dec 23, 2008 | 06:42 PM
Gun Jam's Avatar
Gun Jam
HELL YA...I got ONE I GOT ONE!!!
-Gun
