Please help!!!
Old Dec 22, 2008 | 06:46 PM
Meadracing's Avatar
Meadracing
Default Please help!!!
I have a 66 coupe with a 289. I just rebuilt the motor( new cam bearings, rod bearings, main bearings, rings, honned cylinder walls. new cam;slight above stock, heads refurbished stock, new performer intake, and street avenger carb. I just did the initail cam break in. My problem is I can't get the motor to idel. timming is at tdc as far as I can tell. Can't really tell with out car ideling. idle screw on carb is maxed out. Anyone got any suggestions?
Old Dec 22, 2008 | 07:01 PM
1slow67's Avatar
1slow67
ROTM Moderator
Maybe it is too rich.
Old Dec 22, 2008 | 07:06 PM
Joe67's Avatar
Joe67
Banned
whats the exhaust smoke look like?
Old Dec 22, 2008 | 07:10 PM
Gun Jam's Avatar
Gun Jam
vac leak.
You can fog unburned propane (from a large propane torch) or carb cleaner around the carb base and intake.. If engine tune changes you found the problem child.
You did check the idle stop screw on the throttle linkage right?
-Gun
Old Dec 22, 2008 | 07:11 PM
Meadracing's Avatar
Meadracing
a little smoke.Nothing I would consider to rich
Meadracing's Avatar
Meadracing
stop screw is maxed out
Old Dec 22, 2008 | 07:19 PM
MonsterBilly's Avatar
MonsterBilly
please list the cam that you installed.
Many of the small block ford cams are set up for the 351 firing order. look at the cam specs and it will list the firing order. The car will run with the wrong firing order but it will run crappy and not idle properly
Old Dec 22, 2008 | 07:30 PM
Meadracing's Avatar
Meadracing
Its from NPD;259I/270E duration. 413I/435E lift. I don't see the firing order. Where can I find it.
Old Dec 22, 2008 | 08:00 PM
fakesnakes's Avatar
fakesnakes
It won't idle at TDC. Turn the idle mixture screws all the way in, then back them out 1 1/2 turns. Turn the idle speed screw all the way out, then back in until the throttle plates just start to move. Advance it to about 10 degrees before TDC (turn the distributor CW), then start the car and fine tune your timing, idle, and mixture.
Old Dec 22, 2008 | 08:07 PM
Meadracing's Avatar
Meadracing
This a new 570 Holley Street Avenger Carb. I wouldn't think you would really have to adjust the idle mixing screws that much. Suposed to be close right out of the box.
