help with bushings...
Old Jan 5, 2009 | 07:08 PM
polo708's Avatar
polo708
Default help with bushings...
There are some bushing in my engine bay that are rotted out and I want to replace them. Only problem is that I dont know what they are called so that I can search for them.
They are at the very front of the frame rails where they begin to curve inwards towards each other underneath the radiator. Is this description helpful enough or do I need to snap a pic of them? thanks in advance... again.
Old Jan 5, 2009 | 07:28 PM
1slow67's Avatar
1slow67
ROTM Moderator
Strut rod bushings is what it sounds like.
Old Jan 5, 2009 | 08:03 PM
fakesnakes's Avatar
fakesnakes
Strut rod bushings, two on each side, one on each side of the bracket the strut rod passes through. Your wheels will not stay in alignment and the car will drift around as you drive if they are in really bad shape.
Old Jan 5, 2009 | 08:04 PM
1slow67's Avatar
1slow67
ROTM Moderator
Sounds like my 67 then. I need to replace them. Mine drifts around, but it is also out of alignment. Maybe I will do both this weekend.
Old Jan 5, 2009 | 11:07 PM
flyingfool's Avatar
flyingfool
those nuts on the end of the strut rod can be a bi*$ to get off. i ended up having to use a hollow tube put over my breaker bar to get the leaverage when i did mine.
DanielDoom20
May 24, 2010 01:19 PM
dimebag
Apr 30, 2009 07:40 PM
winfieldjuggalo
Aug 8, 2008 06:10 PM
winfieldjuggalo
Jul 6, 2008 12:16 AM
BAY68_347
Mar 7, 2008 03:40 AM
