Newbie Header w/ PS Hose problem
Old Jan 8, 2009 | 10:04 PM
fakesnakes's Avatar
fakesnakes
Upgrade to a R&P unit!
If you use the wrap, put it around the headers not the hoses. Wrap holds the heat in and that is the last thing you want. A better solution is a thin piece of aluminum sheet mounted between the headers and hose.
Old Jan 8, 2009 | 10:11 PM
Gun Jam's Avatar
Gun Jam
+1 on the fiberglass warp.
Get it wet with water and wrap it tight around the section of the header that would radiate the most heat to the ps lines. Next warp the PS lines as well to shield them from radiation. You don't have to warp the whole length just the areas that are near the header.
-Gun
Old Jan 12, 2009 | 03:57 PM
67two89's Avatar
67two89
thnx for all the responses.... what about Shortys? I have been told that they allow for better clearance and fit .. and could solve the problem.. any thoughts?
Jb145700
Aug 21, 2022 06:37 AM
JDWalton
Sep 24, 2015 08:47 PM
cema93
Aug 10, 2015 09:35 PM
blk2kv6stang
Mar 8, 2004 01:00 AM
el_kid_1
Nov 20, 2003 12:09 AM
