5.0 upgrade...need some info
Old Jan 10, 2009 | 08:06 PM
lawdog205's Avatar
lawdog205
Default 5.0 upgrade...need some info
Heres the low down...putting a EFi 5 litre in my 66 coupe. Surfed aroud and have all the info for the swap..thanks to this site.
Here is my question...can I use the modern AC unit and fit it under my dash..I can live without the glove box..not a problem. I am thinking of taking the radio out and molding the dash back in flush..then using a set of round vents from an F150 to use for the AC/heat vents..there is quite a bit of room under the dash. I figure I can do away with the exterior vent holes that always rust out...just weld a sheet over the holes.
LMK what you guys think...and if this has been done.
Thanks again
Old Jan 10, 2009 | 09:16 PM
JamesW's Avatar
JamesW
check out the Vintage Air Sure-Fit system. it's designed to replace your current heater box for an in-dash A/C installation.
folivier
Tennessee Regional Chapter
Oct 2, 2015 05:32 AM
RCS02v6
Sep 29, 2015 01:46 PM
junior04
Sep 28, 2015 10:53 AM
GLOCKer
Sep 28, 2015 07:36 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
