New carb cuts out, why?
Old Jan 10, 2009 | 10:58 PM
runway1's Avatar
runway1
Default New carb cuts out, why?
Installed a new Edelbrock carb (#1406) and Performer manifold on a 302. It seems to run great and then, if you press the accelerator anything more than veeery gently, it cuts out; like you pulled the fuel line right at the fitting. Pump and fuel lines are all checked out....6.5 psi and all new lines/filter into the carb.
Is the float too low? I thought these were near tuned right out of the box. Any thoughts? Thanks all!
Old Jan 10, 2009 | 11:42 PM
Gun Jam's Avatar
Gun Jam
vac leak maybe. unless its WAAYYY off a float won't cause that issue i would think.
fire it up and fog some carb cleaner at the base of the carb and around the intake..if the engine changes tune then its a vac leak.
are all unused vac ports plugged?
-Gun
Old Jan 11, 2009 | 07:14 PM
runway1's Avatar
runway1
Thanks for the help. I reset the mixture and let it war up and the choke get open - no problems. Thanks again for the input.
Old Jan 12, 2009 | 09:32 PM
nba1341's Avatar
nba1341
still running good?
Old Jan 13, 2009 | 08:55 AM
runway1's Avatar
runway1
Yup. Runs good, feels good. Not like it's getting many miles but so far, so good. A little cough when I start from 0 and punch it.
This 302 was the 2bbl, single exhaust version. Trying to get some ummmmph out of it. I need to look up the specs for compression to see if I can ever get any power out of this thing. Cylinder heads are likely another limiter.
jwog666
Dec 27, 2021 08:09 PM
bradleyb
Nov 27, 2015 07:50 PM
jrrhd73must
Oct 2, 2015 09:17 PM
mdg
Oct 1, 2015 07:04 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
