anyone know where i can get a disc brake set up?
Old Jan 13, 2009 | 01:53 PM
built67's Avatar
built67
thanks for all the help and opinions guys. i might end up going with the manual csrp discs in front and leave the drums in back, bc they arent completely necessary. i have manual drums now and i can deal without the power assist. ill check out the junk yards for that 9" in the meantime...
Old Jan 13, 2009 | 02:24 PM
built67's Avatar
built67
ive run into a slight problem...csrp says the brake set up is only for auto trans only, and i have plans to convert to a 5 speed...
Old Jan 13, 2009 | 02:29 PM
Starfury's Avatar
Starfury
You must be looking at the power kit. The power kit comes with an auto-only brake pedal, iirc.
Old Jan 13, 2009 | 04:38 PM
degins's Avatar
degins
There is a CSRP manual brake kit for all 65-73 Mustangs. It is difficult to mount a booster/dual reservoir master cylinder to 65-66 Mustang with manual trans because of interference from the clutch linkage. This is not a problem with cable or hydraulic clutches. The power kits I offer for 67-70 cars include a brake pedal that has the wide version foot pad correct for auto trans cars. The power upgrade kit is otherwise compatible. The user can swap the foot pad from their existing pedal to the new pedal.
Old Jan 13, 2009 | 10:41 PM
degins's Avatar
degins
Originally Posted by chockostang
To Built 67.
If you put Factory Disc Brakes on your 67, with Factory Booster, Master, and pedal you can run automatic Trans, Standard Trans, makes no difference.
Some of the repo aftermarket force fit Booster are not compatible to the Factory setup.
Doing it with Factory 67 Mustang Parts Guarantees a CORRECT fit, rather than a Fit that requires altering, changing your classic to get pieces, parts to fit.
You can install the Factory 67 Disc Brakes nearly at the same price as the Non Factory 67 Brakes, with a GREAT deal easier time of installing---All Bolt in.
Dan
www.chockostangclassicmustang.com
Huh! The OP is confused about the applicability of the kit being discussed. This confusion is centered on the type of pedal used. FYI, a factory 67 power brake car uses a different pedal than a manual one, and a manual trans car uses a different one than an auto trans car.
We have a duty as forum members to deliver valuable information. Of course we will contribute in the area that we are interested in, and these contributions may tend to promote our interest, but why do you distract every discussion of a disc brake application with self serving nonsense? Contrary for contrary sake is lame. Please, get it right.
Old Jan 14, 2009 | 04:02 AM
kalli's Avatar
kalli
here it is from the horses mouth. Sorry about by post with 65 and manual and powerbooster. problem is not the shock tower brace like I said but the original clutch linkage. makes sense to me now as well as the braces should be the same auto and manual. But you're 67 anyway ;-)
mtgldr
Feb 3, 2024 09:00 PM
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
musnicki
Sep 23, 2015 07:11 AM
maestro1024
Sep 21, 2015 02:40 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
