Differences between Blocks of different years.
Old Jan 16, 2009 | 04:47 PM
  #21
mstg007's Avatar
mstg007
Originally Posted by Gary H
No, you can just knock out the roll pin and take the gear off. Put on a new one and put the pin back in
http://www.jegs.com/p/Ford+Racing/750406/10002/-1
I THINK you need the .467 diameter one, not sure. You might have to drill the roll pin holes in the new gear. If you dont want to do it, any machine shop can take care of it cheap. If they want more than $20, find another.
Use the 68 timing cover.
Gary After all the questions I have asked! You are right! I need to order a steel gear online or ebay. However, How can I find the right size besides using a ruller?
ebay!
http://shop.ebay.com/items/?_nkw=ste...gear&_osacat=0
Thanks again Gary!
mustang monthly
http://www.mustangmonthly.com/techar...ild/index.html
Old Jan 17, 2009 | 06:38 AM
  #22
Norm Peterson's Avatar
Norm Peterson
Best to use vernier calipers for measuring ID. If there's any chamfer on the hole it would be very easy to get the wrong measurement using a ruler. Anything that can measure inside to ±0.010" should be good enough to tell between 0.467" and 0.531".
Norm
Old Jan 17, 2009 | 09:51 AM
  #23
mstg007's Avatar
mstg007
Thanks guys!
I was comparing the drive gears on the following sites:
1989 Drive Gear
http://www.thepartsbin.com/catalog/?...ributor%20gear
1968 Drive Gear
Should I get a Drive gear based on the 89 or the 68 to work with this 89 engine?
And I have a feeling your are going to tell me that it does not matter? lol
Thanks for the help
Old Jan 19, 2009 | 11:34 AM
  #24
Gary H's Avatar
Gary H
The only thing that matters is the distributor shaft diameter. Take a 1/2 in. open end wrench and see if it fits over the shaft. it should fit easily over a .467 shaft, but not over the .531.
Old Jan 19, 2009 | 04:21 PM
  #25
mstg007's Avatar
mstg007
Got it! Thanks! I have a .467.
Gary Thanks again for all your help! I might have more... But I appreciate your time!
Old Jan 19, 2009 | 09:38 PM
  #26
mstg007's Avatar
mstg007
I want to share my Assembly task.
Again, everyone, thanks for your help on this! I can not wait to rebuild this thing!
Notes:
Assembly of engine
Parts from '68 you want to use:
- Timing Cover / Accessories
- Oil Pan
- Intake Manifold
- Carborator
- **** Use 351W Firing Order (MAYBE) Sparkplugs
Use all other parts from the '89 Engine.
Notes: Use the same (We have it all)
- Balancer
- Crank Shaft
- FlexPlate / Flywheel
- Dipstick
- Plug the dipstick tube hole in the block.
- Fuel Pump
- Place the fuel Pump eccentric on the CAM.
- Pulley needs to be a 4 bolt, (Need to center and drill 4 Bolts to match harmonic balancer)
- Distributor
- Change / Swap Iron Gear on Distributor with a Steel Gear. (Shaft is 0.467)
- Place the Prytonic Ignitor, is you have, After the engine starts. Leave Points on until the engine works.
- Heads
- Do not use the '68 Heads (they have differ Length Push rods)
Old Jan 21, 2009 | 11:29 AM
  #27
Gary H's Avatar
Gary H
A couple things... :-)
The spark plugs for the 89 are different from the 68. Also, you need to plug the air pump holes in the back of the 89 heads. Cant remember the size off hand, Ford's part is # : F4ZZ-6E086-A or you can get themr from jegs/summit. Since you have the engine out, you might just look for the right size bolt.
Old Jan 21, 2009 | 12:03 PM
  #28
mstg007's Avatar
mstg007
Sounds good. I will look for them on the heads to see how to patch them.
mustangheaven
Jan 3, 2016 11:20 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
mustangheaven
Sep 29, 2015 11:00 AM
treesloth
Sep 28, 2015 07:03 AM
